JBL Pulse 2 Speaker Replacement
  1. JBL Pulse 2 Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse 2 Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubber rings from either end of the device.
    • If there is difficulty in lifting the rings from the device, use the metal spudger.
  2. JBL Pulse 2 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4.8mm Phillips #1 screws from each end of the device with the Phillips head screwdriver.
    • Lift the end pieces off of the device.
  3. JBL Pulse 2 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 9.5mm Phillips #1 screws from each end of the device.
  4. JBL Pulse 2 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse 2 Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel one end off and slowly draw it across the length of the device until you get to the other side.
  5. JBL Pulse 2 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse 2 Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse 2 Speaker Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 7.9mm Phillips #1 screws along the black centerpiece of the device between the camera and the auxiliary port.
    • Lift up the casing and circuit board but do not try and remove the ribbon wires.
  6. JBL Pulse 2 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cover from the end that the ribbon wires are attached to. It should peel off easily.
  7. JBL Pulse 2 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse 2 Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unlatch the mechanism holding the ribbon wires in place, then disconnect them from the motherboard.
    • To access the wires, remove some of the black glue holding them in place with the spudger.
  8. JBL Pulse 2 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse 2 Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly pull the ribbon wires out from the outside.
    • If there is too much resistance, remove more of the black glue.
  9. JBL Pulse 2 Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse 2 Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 7.9mm Phillips #1 screws around the edges of the center piece.
    • Slide the outer casing off away from the auxiliary and micro USB port.
  10. JBL Pulse 2 Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the other end of the device to access the wiring underneath it.
  11. JBL Pulse 2 Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $3.99
    • Use the angled tweezers to disconnect the battery from the motherboard. It will take some work to remove this piece.
  12. JBL Pulse 2 Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 7.9mm Phillips #1 screws from the black centerpiece of the device.
  13. JBL Pulse 2 Speaker Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse 2 Speaker Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to reach under the sides of the black centerpiece to access the six latches, three of which are on each side.
  14. JBL Pulse 2 Speaker Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse 2 Speaker Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the black centerpiece off with the metal spudger to reveal the battery underneath.
  15. JBL Pulse 2 Speaker Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hot air gun to soften the hot glue in order to fully remove the battery.
  16. JBL Pulse 2 Speaker Replacement, Speaker: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse 2 Speaker Replacement, Speaker: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse 2 Speaker Replacement, Speaker: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the LED strips from the outside of the white plastic casing.
  17. JBL Pulse 2 Speaker Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse 2 Speaker Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse 2 Speaker Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #1 screwdriver to remove the ten 9.5mm screws that hold the cage in place.
    • Lift the cage off to access the internal components.
  18. JBL Pulse 2 Speaker Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse 2 Speaker Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #1 screwdriver to remove the eight 6.4mm screws that hold the speakers in place.
    • Partially remove the speakers so that you can access the components underneath them.
  19. JBL Pulse 2 Speaker Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse 2 Speaker Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the straight tweezers to disconnect the speakers from the motherboard.
    • Fully remove the speakers once they are disconnected from the motherboard.
Emilee Hicks
crwdns2935283:008/31/18crwdne2935283:0
803 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team S1-G1, Virtue Fall 2018 crwdns2935289:0Western Carolina University, Team S1-G1, Virtue Fall 2018crwdne2935289:0
WCU-VIRTUE-F18S1G1
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 1,917
