JBL Pulse 2 Button Circuit Board Replacement
crwdns2942287:0crwdne2942287:0If you are experiencing any difficulties using the buttons on your JBL Pulse 2, you may need to replace the button circuit board.
crwdns2944105:0crwdne2944105:0
Remove the rubber rings from either end of the device.
If there is difficulty in lifting the rings from the device, use the metal spudger.
Remove the four 4.8mm Phillips #1 screws from each end of the device with the Phillips head screwdriver.
Lift the end pieces off of the device.
Remove the four 9.5mm Phillips #1 screws from each end of the device.
Peel one end off and slowly draw it across the length of the device until you get to the other side.
Remove the four 7.9mm Phillips #1 screws along the black centerpiece of the device between the camera and the auxiliary port.
Lift up the casing and circuit board but do not try and remove the ribbon wires.
Remove the cover from the end that the ribbon wires are attached to. It should peel off easily.
Unlatch the mechanism holding the ribbon wires in place then disconnect them from the motherboard.
To access the wires, remove some of the black glue holding them in place with the spudger.
Slowly pull the ribbon wires out from the outside.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:04crwdne2947412:0
where can I buy that part
I love you guys
I need to buy parts
How can I find the cable connecting main board and button circuit
