jbl link 10 battery replacement
peel the bottom cover off
be careful not to damage the charging port
remove the screws that are hidden underneath the base
carefully remove the charging port
be careful of the cables that are still connected to the motherboard.
use a flat screwdriver or spudger to carefully pry up the plastic
carefully unplug the old battery from the 6 pin connector on the motherboard
-be extremely careful not to damage the connector.
carefully take the old battery out.
this should be easy if you are doing it correctly.
