If the battery in your JBL Go 3 over time starts to lose its ability to hold a charge, which is a common issue with speakers, you may need to replace the battery. You can use the guide below to replace the battery on your own.
Use a jimmy or an opening pick to gently lift up a corner of the fabric mesh. Remove the entire fabric and shell
Use the Jimmy to begin taking apart the housing along the seam
Unclip the internal latches as you go around
Under the rubber strip you'll see a few small screws.
Use screwdriver to unscrew
gently use jimmy to open the speakers housing
Unscrew motherboard before locating battery
Look for the battery (usually wrapped in a black or silver covering)
Battery is connected to mainboard by a small cable
Disconnect the battery connector from the circuit board
