JBL Flip Speaker Replacement
  1. JBL Flip Speaker Replacement, JBL Flip disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip Speaker Replacement, JBL Flip disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip Speaker Replacement, JBL Flip disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the end with the buttons, remove the end cap using the flat head screwdriver to get between the rubber lining and the plastic.
    • After the cap is removed, unscrew the two 3.3mm screws using a size 1 ph screw driver.
  2. JBL Flip Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip Speaker Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew four 3.3mm screws on each end of the JBL using a size 1 ph screw driver (8 screws total).
  3. JBL Flip Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip Speaker Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove outermost white casing by gently lifting up on one side.
    • Remove two 5mm screws holding the silver back plate in place with a size 2 ph screw driver.
    • Gently lift up and remove the silver casing.
  4. JBL Flip Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove last white back plate to expose the back of the speaker cover.
    the metal cover looks upside down to me: holes for rubber legs and DC jack should not come on one side (like in the pictures above)
    Albrecht Duerer - crwdns2934203:0crwdne2934203:0
  5. JBL Flip Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip Speaker Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the four tabs on each side of the speaker cover (8 tabs total).
    • Pry the two tabs on each end to remove the cover (4 tabs total).
    • Slide speaker out of metal speaker cover.
  6. JBL Flip Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip Speaker Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 5mm screw in the middle of the back of the device with a size 2 ph screw driver.
    • Unscrew the two 5mm screws on each side using a size 2 ph screwdriver.
    • Open the speaker.
  7. JBL Flip Speaker Replacement, Speaker: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip Speaker Replacement, Speaker: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip Speaker Replacement, Speaker: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove screws that hold the plastic L-pipe in place.
  8. JBL Flip Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove L-pipe.
    • Remove two screws on each speaker.
    • Remove speakers.
  9. JBL Flip Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip Speaker Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take a soldering iron to the two solders, one for each cable.
    • Soldering iron will be very hot.
    • Once the soldering has melted, remove each wire from the speaker.
    What is the specification of the speaker?
    Krishna Upadhyay - crwdns2934203:0crwdne2934203:0
Dillon
crwdns2935283:003/11/15crwdne2935283:0
1.559 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 9-5, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 9-5, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S9G5
crwdns2947412:09crwdne2947412:0
I want JBL flip 2 charging commector board.
Where can i buy ??
Plz help me
feroz4u786 - crwdns2934203:0crwdne2934203:0
Where do you buy the replacement speakers?
ingridxpan - crwdns2934203:0crwdne2934203:0
I have a problem with the bluetooth of my speaker goes off after 10 minutes of running I have checked with several smart and it always repeats that I can do
Alvaro Rivas Rodriguez - crwdns2934203:0crwdne2934203:0
Where I can get schematic diagram and plans of this equipment
I want to buy 2pcs replacement speaker for my JBL flip bluetooth speaker. Ho can I buy .and from
jonessangeeta - crwdns2934203:0crwdne2934203:0
I also want new replacement speaker,can you tell me from where you have brought
Chandu dhinwa -
Belt on off switch bluetooth ti circuits joint belt
kiritc69 - crwdns2934203:0crwdne2934203:0
i need jbl flip 2 speaker, where can i buy for it?
Rommel cruz - crwdns2934203:0crwdne2934203:0
I want to know what type of flex cable is used in button panel of JBL flip 1 speaker A type or B type
Poonam Sharma - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 67
crwdns2942667:0crwdne2942667:0 42,607
