JBL Flip 6 Motherboard Replacement
  1. JBL Flip 6 Motherboard Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 6 Motherboard Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the iFixit opening tool, pry up on the button side of the slot on the case until the clips release.
  2. JBL Flip 6 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now that the gap is larger, using the same tool, pry up on the other side until the clips release.
  3. JBL Flip 6 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With all clips released, slide the case off longways.
    • You may need to spread it a bit with your hands so that the clips do not become caught on the end pieces.
  4. JBL Flip 6 Motherboard Replacement, Tweeter: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 6 Motherboard Replacement, Tweeter: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 9.5-mm Philips #1 screws securing the tweeter to the device.
  5. JBL Flip 6 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick into the gap along the edge of the tweeter.
    • Push the tip inwards and pry upwards to release the tweeter from the motherboard.
  6. JBL Flip 6 Motherboard Replacement, Passive Radiators: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 6 Motherboard Replacement, Passive Radiators: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a prying tool to lift up on one of the clips that holds the radiator in place.
  7. JBL Flip 6 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the clip has been released, insert a shim to keep the parts separated and from the clipping back together.
    • Pry on the clip on the other side to fully release the passive radiator.
  8. JBL Flip 6 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After both clips have been detached, the passive radiator is easier to remove by hand.
    • Repeat the same steps for the passive radiator on the other side.
  9. JBL Flip 6 Motherboard Replacement, Woofer: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement, Woofer: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement, Woofer: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 9.5 mm Philips #1 screws securing the woofer to the device.
  10. JBL Flip 6 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully disconnect the white connector linking the woofer and the motherboard.
    • If there is a lot of resistance when removing the plug, there could be a clip holding it in place. Check for any sort of fasteners before using much strength as you could damage the motherboard.
  11. JBL Flip 6 Motherboard Replacement, Charging Port: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 6 Motherboard Replacement, Charging Port: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to release the clips attaching the cover for the buttons and charging port.
    • After the two clips are removed, the cover can be removed easier by hand.
  12. JBL Flip 6 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the clips have been released, take the cover off, feeding the strap out of the hole.
  13. JBL Flip 6 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 5.7 mm Philips #00 screws holding the charging port cover in place.
  14. JBL Flip 6 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers, pull the blue ribbon from the connector from the charging port board.
    • After the ribbon is removed, pull the USB-C port out from the outside.
  15. JBL Flip 6 Motherboard Replacement, Motherboard: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement, Motherboard: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement, Motherboard: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull the small ribbon cable from its slot.
    • Lift up on the black locking flaps opposite the ribbon cables, then carefully pull the ribbon cables out of their slots.
  16. JBL Flip 6 Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully disconnect the small ground connector from the motherboard.
    • When reattaching this connector, it can be tricky to line up and get it to set. The best way to do it is to position the wire with your non-dominant hand, then, using tweezers, pinch the topside of the motherboard and the connector.
  17. JBL Flip 6 Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 9.5 mm Philips #1 screws securing the plastic retainer for the battery and motherboard.
  18. JBL Flip 6 Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry up on the black tab, then carefully pull the connector from its port on the motherboard.
  19. JBL Flip 6 Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push on the inside edge of the motherboard until the battery connector is outside of the device case.
    • Pinch and pull up on the battery connector to release it, freeing both the motherboard and the battery for removal.
  20. JBL Flip 6 Motherboard Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 6 Motherboard Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull out both the battery and motherboard, and repair or replace as needed.
Cody Chamberlain
crwdns2935283:009/25/24crwdne2935283:0
414 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 1-1, Sneed Fall 2024 crwdns2935289:0University of Memphis, Team 1-1, Sneed Fall 2024crwdne2935289:0
UM-SNEED-F24S1G1
crwdns2936753:030crwdne2936753:0 84
crwdns2942667:0crwdne2942667:0 430
