JBL Flip 4 USB Port Replacement
  1. JBL Flip 4 USB Port Replacement, Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 USB Port Replacement, Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 USB Port Replacement, Shell: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
    • Watch out not to damage the clips on the buttons' side, pry open with caution.
    • Pull the cover off with your thumbs.
  2. JBL Flip 4 USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 USB Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 USB Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four 13 mm JIS #0 screws attaching the rubber spine to the speaker, located on both sides of the inside of the speaker.
    • Use the plastic opening tool to release the clips holding the central part of the rubber spine.
    • Pry away one end of the rubber spine with your thumbs and it should come off.
    • Prying off the spine may take some persuading.
    • The speakers are strong magnets. Keep it away from other sensitive electronics.
  3. JBL Flip 4 USB Port Replacement, USB Port: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 4 USB Port Replacement, USB Port: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 9mm Phillips #1 screws holding the gray USB port.
    • Loosen the USB cover's gray casing using your hands.
  4. JBL Flip 4 USB Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 4 USB Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Twist or remove screws from the cap. (depends on your model-version: only older versions have 9mm Phillips #1 screws)
  5. JBL Flip 4 USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 4 USB Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the wire coated with dark gray foam out from the space where it is tucked and move it out of the way.
  6. JBL Flip 4 USB Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 USB Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 USB Port Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unhook the white plug attached to the small circuit board hanging from the gray micro USB casing using the ESD Safe Blunt Nose Tweezers.
    • Move the plug out of the way by pulling it through the gap in the large circuit board to get to the next plug behind it.
  7. JBL Flip 4 USB Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 4 USB Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unhook the other smaller white plug behind the previous plug from the same small hanging circuit board using the tweezers.
  8. JBL Flip 4 USB Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the gray USB port out of the speaker.
    • Do not yank on this component as it is still attached by wires.
  9. JBL Flip 4 USB Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 USB Port Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 USB Port Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unhook the small white plug attached to the main circuit board that is holding the USB port to the speaker.
    • Remove the USB port component from the speaker.
  10. JBL Flip 4 USB Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 4 USB Port Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove three 9mm Phillips #1 screws holding the two small circuit boards to the USB port component.
    • Pry off the top small circuit board with the plastic opening tool.
    • You will have to use some force to remove this board as it is glued down.
  11. JBL Flip 4 USB Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 4 USB Port Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back the black adhesive on the bottom side of the component with the tweezers and remove the wires underneath.
    • Remove the first small circuit board and attached wires.
  12. JBL Flip 4 USB Port Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 4 USB Port Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the second circuit board by pulling on it with your hands.
    • You may need to pull hard on this small circuit board as it is also glued in some places.
crwdns2935229:030crwdne2935229:0
Philip Pang
crwdns2935283:010/08/18crwdne2935283:0
1 380 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S4-G3, White Fall 2018 crwdns2935289:0Cal Poly, Team S4-G3, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S4G3
crwdns2935297:037crwdne2935297:0
crwdns2947412:012crwdne2947412:0
Hi, I need to replace this circuit board where the charging port mounts.
While trying to remove damaged micro usb port, I damaged the tiny wires from the circuit board.
I tried to find this online but no luck so far.
Do you know the code for this PCB?
Thank you,
alex garcia - crwdns2934203:0crwdne2934203:0
hi, where can i buy new circuit board for micro usb charging port?
joseph celerio - crwdns2934203:0crwdne2934203:0
I have a question on the small circuit board (charge port), one of the female port on it is for power (+5v), but what is another one? Is it D+, D- ?
P.S. I’ve measure that port with micro usb connected to power source, turns out there has no voltage measured, but the bigger one does has 5v measured.
Thanks!
馮會鈞 - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 80
crwdns2936753:030crwdne2936753:0 467
crwdns2942667:0crwdne2942667:0 69,427
