JBL Flip 4 Shell Replacement
  1. JBL Flip 4 Shell Replacement, Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Shell Replacement, Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Shell Replacement, Shell: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
    • Watch out not to damage the clips on the buttons' side, pry open with caution.
    • Pull the cover off with your thumbs.
    Important suggested edit to these instructions - make sure to pry off clips/ridges from BOTH sides before attempting removal of the cover.
    I interpreted these instructions as saying you only needed to pry clips from one side - then peel off cover. Doing this broke a clip from the other side. Bummer. I'd like others to avoid that.
    k9612 - crwdns2934203:0crwdne2934203:0
    If you do break a clip - save it. They are relatively easy to glue back into the cover.
    k9612 -
    My Flip4 had a single long clip on the non-button side that ran the entire length of the rubber spine. The other side (with play/ vol buttons) had three seperate clips (middle and both sides) as mentioned above.
    takentrashout - crwdns2934203:0crwdne2934203:0
    What if my speaker battery dies very fast and makes weird crackling noise, is it counted as faulty battery?
    Jayden Koh - crwdns2934203:0crwdne2934203:0
    Yes. I first thought one of the drivers was defective.
    Paul Sommer -
    What was the fix in the end ?
    Jack Mulcahy -
    I used the flared edge of a metal measuring spoon handle since I didn’t have an opening tool. Worked great! Replacement battery from iFixit is on order. Thanks for the guide!
    Greg - crwdns2934203:0crwdne2934203:0
    My battery was glued. Tried it anyway to remove. Battery exploded!!!!
    Don't go on if the battery is glued.
    darthvader007 - crwdns2934203:0crwdne2934203:0
  2. JBL Flip 4 Shell Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Shell Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Shell Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four 13 mm JIS #0 screws attaching the rubber spine to the speaker, located on both sides of the inside of the speaker.
    • Use the plastic opening tool to release the clips holding the central part of the rubber spine.
    • Pry away one end of the rubber spine with your thumbs and it should come off.
    • Prying off the spine may take some persuading.
    • The speakers are strong magnets. Keep it away from other sensitive electronics.
    Suggested Edit : Be careful when removing the screws that they don't get attracted to the speaker (magnet). They can scratch the speaker.
    Note : screws don't need to be removed from their “channel” (it’s quite difficult). Just unscrew fully and leave in channel.
    Note or precaution: Place a piece of cardboard over the speaker or use a plastic/rubber/nonmetalic handled screwdriver when loosening/removing the 13 mm screws. The speaker magnets are so powerful that the end of my metal jewelers phillips screwdriver was pulled into the speaker, tearing the plastic/rubber cone. I destroyed two speakers in the process of replacing the battery. Had to buy the speakers from JBL ($16 each).
    Clark Brown - crwdns2934203:0crwdne2934203:0
    The rubber spine was fixed with glue strips.
    Jaider - crwdns2934203:0crwdne2934203:0
    I have 2 Flip 4's bought approx. a year apart. The older speaker was exactly as described here. The newer speaker does not have the 5 end screws, instead it has a twist to lock end plate. Make sure the top screws that secured the rubber end are removed, as these will prevent end cap twisting. I used rubber gloves to get a grip and twist end cap counter-clockwise to unlock. I found that if you grip end cap too tight it makes it even harder to twist off. Someone may find a better solution, like prising the tags around circumference, but be warned these look flimsy.
    Phil - crwdns2934203:0crwdne2934203:0
    Great guide. Only problem is that the battery on mine was in a neoprene sheath and had swollen. It was a bit of a problem to get out. There didn’t seem to be room to fit something to push it out without damaging wires or the motherboard. At the risk of a fire, I worked it back and forth and pulled with a pair of needle nose pliers. Yes there were sparks and some smoke. I did it outside and knew I was risking the whole thing catching on fire. Luckily it went ok.
    Q Switch - crwdns2934203:0crwdne2934203:0
    Great guide! I have a model with the twist-off caps (not 5 screws) with helpful, though subtle, lock/unlock icons on the plastic. Only other problem was replacing the white neoprene battery retainer cover (2 screws). One screw slipped off my screwdriver and fell into the unit - probably stuck to a speaker magnet now. But it doesn't seem to be affecting the sound. iFixit is the best!!
    Jen Morris - crwdns2934203:0crwdne2934203:0
    Una duda tienen la tapa que lleva al principio la bici en la parte de afuera
    Alexis Jesus - crwdns2934203:0crwdne2934203:0
    on the version w/o the five screws: Make sure that you push the lid at the cap where it says “R”to the outside far enough to be able to turn off the cap.
    The Beginner - crwdns2934203:0crwdne2934203:0
    In my case the screws where very tight and i couldnt access them very nice. i had to remove the speakers to get a better angle
    Melvin - crwdns2934203:0crwdne2934203:0
crwdns2935229:09crwdne2935229:0
Philip Pang
crwdns2935283:010/08/18crwdne2935283:0
1.353 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S4-G3, White Fall 2018 crwdns2935289:0Cal Poly, Team S4-G3, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S4G3
crwdns2935297:037crwdne2935297:0
教程不难, 难的是哪里可以买到配件。
Toki - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 190
crwdns2942667:0crwdne2942667:0 15,623
