JBL Flip 4 Front Active Speaker Replacement
  1. JBL Flip 4 Front Active Speaker Replacement, Front Active Speaker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Front Active Speaker Replacement, Front Active Speaker: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Front Active Speaker Replacement, Front Active Speaker: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, it will make a snapping sound.
    • Pull off the cover with your thumbs.
  2. JBL Flip 4 Front Active Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all four 10 mm JIS #1 screws around the damaged front active speaker.
    • The speakers are strong magnets. Keep metal tools or other magnetic objects away from the driver.
  3. JBL Flip 4 Front Active Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Front Active Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Front Active Speaker Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool under the unscrewed front active speaker.
    • Pry off the front active speaker with the opening tool.
    • Do not yank the front active speaker out. It is connected to wires within the device.
  4. JBL Flip 4 Front Active Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut the red, white, and black wires connected to the speaker using wire cutters.
    • You will need to re-solder these wires when installing the new speaker.
    where can i find replacement speaker
    Soan Soram - crwdns2934203:0crwdne2934203:0
    Die Kabel müssen abgelötet werden!
    Sie haben auf der Platine auch eine Steckverbindung.
    Und was nützt die beste Anleitung, wenn man die Lautsprecher nicht bekommt.
    DER - JAK - crwdns2934203:0crwdne2934203:0
    Ersatzlautsprecher habe ich bei Ebay gesehen.
    Oliver Bauer -
crwdns2935229:014crwdne2935229:0
Ryan Whitlock
crwdns2935283:010/08/18crwdne2935283:0
2,292 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S4-G3, White Fall 2018 crwdns2935289:0Cal Poly, Team S4-G3, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S4G3
crwdns2935297:037crwdne2935297:0
crwdns2947412:017crwdne2947412:0
And where can you find the replacement part? I cannot find a replacement speaker on the internet…
Sven Meirsman - crwdns2934203:0crwdne2934203:0
Exactly, what is the part number for the internal speaker?
Dan The Menace Brenes - crwdns2934203:0crwdne2934203:0
The part number is: psp00018001
Johankat -
If the magnet comes loose from the speaker how do you get it back on?
Andrew Sumahit - crwdns2934203:0crwdne2934203:0
Replace the entire speaker.
Magnet realignment is crucial for the speaker to perform properly.
Johankat -
Why does this transducer have 3 terminals?
aswinjayan007 - crwdns2934203:0crwdne2934203:0
From what I can read it's for shielding, to reduce interference. But I also read that it would not be very effective.
Looking at the transducer, the white wire is merely connected to the chassis.
It can be omitted, so no need to find a replacement that has a shield lead.
Johankat -
Where I can find the replacement speaker
quesitosmr - crwdns2934203:0crwdne2934203:0
I couldn’t find replacement drivers for the flip 4 so I just duck taped the driver pads, they work ok now.
maxwell mayhew - crwdns2934203:0crwdne2934203:0
It really work??
Le Charo du 35 -
For replacement speakers Google is your friend.
You can find fully disassembled kits for 10-20usd.
Speaker Id: psp00018001
Johankat - crwdns2934203:0crwdne2934203:0
Hello, I live in Brazil, if I open the plastic/cloth part to see if my speakers are damaged will I void my warranty?
Owskee - crwdns2934203:0crwdne2934203:0
I have a Flip 4 where I just replaced the motherboard. However the wires that are attached leading up to splice with the speaker are aluminum. My speakers off the original Motherboard has copper wire. After splicing the 2 together, i checked for continuity and it was successful but i did not have any sound from the speaker. Please Help
Marcus King - crwdns2934203:0crwdne2934203:0
Der Austausch ist nicht das Problem. Aber wo bekomme ich ein Ersatzteil her. Mit der Nummer psp00018001 finde ich im Netz nichts.
michael.bunte - crwdns2934203:0crwdne2934203:0
Ich habe erst vor kurzem Ersatzlautsprecher auf Ebay gesehen.
Oliver Bauer -
Where to find these speakers? Have googled but could not find any that ships to the Netherlands!
Ronald Blaas - crwdns2934203:0crwdne2934203:0
Woher weiß man genau welcher der beiden Lautsprecher kaputt ist oder muss man beide ersetzen?
xtur005 - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 60
crwdns2936753:030crwdne2936753:0 244
crwdns2942667:0crwdne2942667:0 38,621
