JBL Flip 4 Battery Replacement
  1. JBL Flip 4 Battery Replacement, Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement, Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement, Shell: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
    • Watch out not to damage the clips on the buttons' side, pry open with caution.
    • Pull the cover off with your thumbs.
  2. JBL Flip 4 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four 13 mm JIS #0 screws attaching the rubber spine to the speaker, located on both sides of the inside of the speaker.
    • Use the plastic opening tool to release the clips holding the central part of the rubber spine.
    • Pry away one end of the rubber spine with your thumbs and it should come off.
    • Prying off the spine may take some persuading.
    • The speakers are strong magnets. Keep it away from other sensitive electronics.
  3. JBL Flip 4 Battery Replacement, remove cap: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement, remove cap: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement, remove cap: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The end cap opposite to the USB port: Twist - or - remove screws from the cap. (depends on your model-version: only older version have 9mm Phillips #1 screws)
    • Pull the end cap off with your hands.
  4. JBL Flip 4 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two 11mm Phillips #1 screws on the battery cover.
    • Pull the battery cover off with your hands.
  5. JBL Flip 4 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the large white plug that connects the wires from the battery to the main board using your hands.
    • Pull the battery out with your hands.
    • If the battery is swollen, you might not be able to pull it out with your hands, you might just rip the cables+charging board out.
    • In this case, follow this additional guide for pushing out the battery. Summarized: You can try to remove the other radiator, unscrew the charging port and gently pull it out just a bit so a large screwdriver's end - without its bits - can fit in and push out the battery from this side.
    • The port might be hot glued and under the tapes there are very small normal and ribbon cables, so be careful not to cut or rip them.
crwdns2935229:0181crwdne2935229:0
Philip Pang
crwdns2935283:010/08/18crwdne2935283:0
1,380 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S4-G3, White Fall 2018 crwdns2935289:0Cal Poly, Team S4-G3, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S4G3
crwdns2935297:037crwdne2935297:0
crwdns2947412:076crwdne2947412:0
Is the battery glued into the socket like the Flip 3?
Kenneth - crwdns2934203:0crwdne2934203:0
No it isn’t. but the black rubber around it makes it really hard to get out. try to push it from the otherside by removing the charging-port.
Be careful not to pierce the battery
Richardo Otros -
Yes with me the battery was glued
Diter Freeman -
Be careful and don’t do like me: my old battery was bloated, so I had to push from the other side, but when doing so, I ripped the ribbon cable from the power button… now trying to find a replacement cable
jmbarroso -
Did you find the cable of the power button?
mohamed da -
crwdns2936751:024crwdne2936751:0 65
crwdns2936753:07crwdne2936753:0 452
crwdns2936753:030crwdne2936753:0 2,279
crwdns2942667:0crwdne2942667:0 270,568
