JBL Flip 3 Power Circuit Board Replacement
  1. JBL Flip 3 Power Circuit Board Replacement, Power Circuit Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove plastic outer housing using hands or a standard spudger.
    • Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
  2. JBL Flip 3 Power Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove outer housing to expose the inner components of the speaker.
    On my Flip 3, there were two Phillips head screws on each end that required removal prior to outer housing removal.
    Skeletwing - crwdns2934203:0crwdne2934203:0
    This is fundamental to specify that this is the SE (Stealth edition). The disassembly is not exactly the same (SE edition is easier)
    cottet cyril - crwdns2934203:0crwdne2934203:0
  3. JBL Flip 3 Power Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the silicone button cover to expose the power chip.
  4. JBL Flip 3 Power Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the adhesive at the far end of the chip where the ribbon goes down into the device. Using the spudger, gently pry the chip off the board. Be careful not to melt the plastic edging during heating.
    • Heat gun safety: http://www.powertoolinstitute.com/pti_pd...
    removal of the mainboard is essential if you need to replace the battery for example; it is not shown here
    Dirk Winning - crwdns2934203:0crwdne2934203:0
crwdns2935229:014crwdne2935229:0
James Bianco
crwdns2935283:002/20/17crwdne2935283:0
151 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G2, Leahy Spring 2017 crwdns2935289:0USF Tampa, Team S1-G2, Leahy Spring 2017crwdne2935289:0
USFT-LEAHY-S17S1G2
crwdns2935297:018crwdne2935297:0
crwdns2947412:05crwdne2947412:0
If your gentle, you don’t need a heat gun. I carefully removed it with a screwdriver. Just don’t stress the board else your in a new set of problems.
Tyler Freeman - crwdns2934203:0crwdne2934203:0
How do you remove the board? It says to remove the chip from the board but there are no images that show that.
Brian Barlow - crwdns2934203:0crwdne2934203:0
The title says replacement, and you show only the removal.
Stanimir Nikolov - crwdns2934203:0crwdne2934203:0
what could be a problem with my jbl flip 3.it wouldn't turn on when its not plugged in to the charger.
Miss D - crwdns2934203:0crwdne2934203:0
Change the battery
odii Emmanuel -
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 87
crwdns2942667:0crwdne2942667:0 31,600
