You love your JBL Flip 3, but the battery is running low? No need to panic! With this step-by-step guide, we'll show you how to replace your speaker's battery yourself. It's easier than you think - and more environmentally friendly than buying a new device. You can do it!
Pry up the two tabs on one side using a spudger.
Pry up the other two tabs, they are located on the other side.
Remove the cover carefully.
Unscrew the four screws located on the edge.
Remove the second protective cover carefully.
Repeat the same steps in reverse order to reassemble your device.
crwdns2935229:05crwdne2935229:0
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
What’s your problem?
Uncomplete and Sketchy!
How come is this a battery replacement guide? It is only up to the removal of the second protective layer. Many questions remain: How to locate the battery? How to unplug it? How to remove it? How to plug the new one? How to reassamble? …
You're right, the current version does not answer your questions. However, it seems that 5 people could still successfully repair their device with the help of that guide, so rather than taking it down, we'd suggest you and others help complete the guide by adding your pictures and information you found?
