This guide will walk you through from taking apart the device, disconnecting all the cables inside and taking out the I/O board in order to replace the auxiliary port.
Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
Remove the eight 7.0 mm Phillips #1 screws on both sides of the JBL Flip 2.
The NFC chip is glued onto the side of the device. Use the black spudger to separate the mic from the surface.
Gently slide the NFC chip into the device through the slot that the wire comes from.
what if the wire DID disconnect? could s.o. add a detail pic of exactly where the cables connect on the chip?
Need the real name of the NFC chip, caus i broked and need to change
Thanks
Need the real name of the NFC chip, cause i broked and need to change
Thanks
My chip reads
WN-3088 20130912
Peel the black rubber piece from one end to the other.
Remove the two 7.0 mm Phillips #1 screws.
Carefully detach the silver plastic cover by pulling both ends off.
Separate the silver plastic piece by pulling it off from the middle.
Tutto molto interessante.
Ma la cosa più importante è:
Dove acquistare gli altoparlanti ??
Using a flat-head screwdriver or spudger, pry out the 8 metal nibs on the back side of the speaker.
Repeat the same process for the 4 remaining metal nibs (two on each end).
Expand the metal casing and carefully slide it off the speaker.
Using the driver adapter, first insert the #4 socket into the driver; followed by the #1 Philip's head bit in order to reach the three 13.0 mm screws.
Using the classic spudger, get underneath the black tape strips found on both side of the device.
After lifting a portion of the tape off of the device, gently peel the tape off of the device, making sure to keep it intact.
There is another piece of tape on the side of the device with the control buttons. Lift the tape with the classic spudger and then peel the rest of the tape off.
For easier removal warm the tape up with a hair dryer. It tears apart very easily.
Keeping the tape intact is impossible - I replaced it with electrical tape.
Wedge a spudger between the two halves where the tape was to pry the device open.
Use the black spudger to disconnect the speaker cord from it's socket.
Use the black spudger to disconnect the auxiliary wire from its socket.
What is the function of auxi. Wire
When you plug in the audio jack it goes to the motherboard, the amplifier and then to the wire directly to the speakers.
Carefully remove the cable connecting the control chip to the motherboard.
What's the name of the cable connecting the control chip to the motherboard
I want motherboard control chip
connecting the control chip kitne ka hai
Using the black spudger, carefully remove the cord connecting the battery to the motherboard.
If you can“t see a connector here , you have an earlier version of Flip2 - the connector is on the backside and requires a different battery - see the comment at the end of the feature
Carefully remove the cable connecting the nfc chip to the motherboard.
Remove the one 7.0 mm Phillips #1 screw that connects the I/O board to the casing.
Remove the cord that connects the I/O board to the motherboard.
Put the motherboard to the side.
With the black spudger, carefully wedge out the I/O board.
Aku sudah mencobanya tp kabel yg biru putus karna emang udah ketekuk dr pabrikanya
Gently pull the I/O board out from the speaker.
Desolder the auxiliary port to remove it from the I/O board..
Is It hard to repair ? I have one that is not charging, I don't know if is the battery or the usb port.
Where can I purchase the auxiliary port (preferably in Europe)?
From where i can buy these speakers?
Nitin Z - crwdns2934203:0crwdne2934203:0
First thing I did was rip the wire from the NFC chip! Luclily I don't need it as I only ever use my flip with my iPhone.
Ken McMahon - crwdns2934203:0crwdne2934203:0
