Headphones not connecting to the auxiliary? This may be caused by the headphone jack. Here's a guide to replace it. All you will need is a Phillips #00 screwdriver, a soldering iron, and an iFixit opening tool.
Remove the ear pad with an opening pick.
Remove the 4.5 mm screws using the Phillips #00 screwdriver.
Pull apart the bronze speaker away from the headphones carefully to reveal the wiring.
Desolder the motherboard speaker connection.
Unscrew the circuit board connected to the headphone jack.
Desolder the cables connecting the headphone jack board to the headphones.
