If the headband of your headphones displays signs of wear and tear or provides discomfort, then this guide is perfect for you. This guide will help you easily remove and replace the headband. All you need is a Phillips #000 screwdriver, an iFixit opening pick, and a SIM card ejector.
Extend the headphone.
Bend the hinge slightly, then remove the two .5 mm screws with a Phillips #000 screwdriver.
Use a SIM tool to push pin fully through and out.
Go along the edges with the pick, and pull up, taking off the band.
After fully taking off the band, you are now ready to insert in the new band.
When placing in the new headband, line up the holes as shown in image 2.
