JBL Clip Plus Speaker Replacement
  1. JBL Clip Plus Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $3.99
    • Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
  2. JBL Clip Plus Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There will be three 6mm philips head screws under that rubber bumper, remove these three screws.
  3. JBL Clip Plus Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The back cover should lift open easily and the components should be visible.
  4. JBL Clip Plus Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is adhered to the back cover of the JBL Clip Plus, slowly lift the battery away from the case, using a spudger to pry the battery away from the adhesive.
  5. JBL Clip Plus Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 7mm philips head screws on the outer edges of the device.
  6. JBL Clip Plus Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic prying tool to gently remove the face of the speaker from the body.
  7. JBL Clip Plus Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger tool to gently scrape away the adhesive holding in the microphone.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  8. JBL Clip Plus Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently push the motherboard away from the microphone, this will allow you to remove the microphone.
  9. JBL Clip Plus Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently push the motherboard out from the frame of the JBL Clip Plus, this requires some force.
  10. JBL Clip Plus Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are three solder points that need to be desoldered.
    • If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
  11. JBL Clip Plus Speaker Replacement, Speaker: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are two #1 philips head 4mm screw fastening the speaker to the body, remove these.
  12. JBL Clip Plus Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
Noah Pauk
crwdns2935283:002/08/16crwdne2935283:0
809 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-4, Baechle Spring 2016 crwdns2935289:0IUPUI, Team 3-4, Baechle Spring 2016crwdne2935289:0
IUPUI-BAECHLE-S16S3G4
do you know were can i buy the new speaker for my jbl clip +?
ruitherock - crwdns2934203:0crwdne2934203:0
I work in A/V. I frequently need to adjust audio systems.
I want to add a switch to the speaker wire, so I can turn the speaker off, and use the line out port only, in order to test audio systems with a Bluetooth reciver.
I can be at the mixing board, adjusting sliders while the music is playing, with no cables.
Will this work?
Donald Fournier - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 7,270
