JBL Clip 3 Motherboard Replacement
  1. JBL Clip 3 Motherboard Replacement, Speaker Grill: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Clip 3 Motherboard Replacement, Speaker Grill: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Motherboard Replacement, Speaker Housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Clip 3 Motherboard Replacement, Speaker Housing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Clip 3 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
  5. JBL Clip 3 Motherboard Replacement, Carabiner Clip: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Clip 3 Motherboard Replacement, Carabiner Clip: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the metal carabiner clip from the speaker housing.
    • They are not glued together and should separate easily.
    • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
  6. JBL Clip 3 Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Clip 3 Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to release the two cable connections from the motherboard.
    • The wires connecting to the battery are not very long, so be careful when removing them.
  7. JBL Clip 3 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the four screws.
  8. JBL Clip 3 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Clip 3 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the motherboard away from the speaker housing.
    • Desolder the two contact points.
Tyler Molden
crwdns2935283:003/28/22crwdne2935283:0
497 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-5, Petersen Spring 2022 crwdns2935289:0UMass Dartmouth, Team 1-5, Petersen Spring 2022crwdne2935289:0
UMASSD-PETERSEN-S22S1G5
crwdns2942667:0crwdne2942667:0 1,179
