JBL Clip 3 Button Board Replacement
  1. JBL Clip 3 Button Board Replacement, Button Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Clip 3 Button Board Replacement, Button Board: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening tool between the speaker grille and speaker housing and pry around the entire perimeter of the device until the grille is released.
    • A strong adhesive attaches the grill to the housing and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Button Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Clip 3 Button Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Button Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the speaker housing from the rest of the body.
    • Carefully lift the speaker housing since there are components that are connected to the speaker housing.
    • The speaker housing and the body are not glued together.
  4. JBL Clip 3 Button Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Clip 3 Button Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the 2-pin and 4-pin connectors from the motherboard.
    • Tweezers can also be used to remove the 2-pin and 4-pin connectors.
  5. JBL Clip 3 Button Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Clip 3 Button Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Clip 3 Button Board Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the two 6.3 mm screws.
    • Carefully remove the internal speaker from the speaker housing.
    • This step is completely optional; completing this step will help unclutter the speaker housing, allowing you to unscrew the last final screws easier.
  6. JBL Clip 3 Button Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Clip 3 Button Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Clip 3 Button Board Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the two 6.3 mm screws from the button board.
    • Carefully lift and remove the button board from the speaker housing.
    • When reassembling your device, remember to use super glue to reattach the grille to the speaker housing.
Adrian Mayorga
crwdns2935283:010/21/24crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 3-2, Harris Fall 2024 crwdns2935289:0CSU Los Angeles, Team 3-2, Harris Fall 2024crwdne2935289:0
CSULA-HARRIS-F24S3G2
crwdns2942667:0crwdne2942667:0 242
