JBL Clip 3 Battery Replacement
  1. JBL Clip 3 Battery Replacement, Speaker Grill: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Clip 3 Battery Replacement, Speaker Grill: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Battery Replacement, Speaker Housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Clip 3 Battery Replacement, Speaker Housing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Clip 3 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
  5. JBL Clip 3 Battery Replacement, Carabiner Clip: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Clip 3 Battery Replacement, Carabiner Clip: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the metal carabiner clip from the speaker housing.
    • They are not glued together and should separate easily.
    • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
    I’ve looked online and can’t find a place to buy the replacement clip. Any tips?
    Elizabeth Morgan - crwdns2934203:0crwdne2934203:0
    Yea, me too. I’m glad I know how to replace it now but where do I get the part???
    Dustin Frank - crwdns2934203:0crwdne2934203:0
    Agree. Showing how to replace a part when no replacment part is available is not at all helpful.
    Ed McAuliffe - crwdns2934203:0crwdne2934203:0
    Has anyone found this part yet? I have 2 of these speakers that need a new clip!
    Paul J. Garay - crwdns2934203:0crwdne2934203:0
    Another option is to remove the clip altogether as it is not fixable. Works fine without it!
    Paul J. Garay -
  6. JBL Clip 3 Battery Replacement, Speaker Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Clip 3 Battery Replacement, Speaker Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to lift the two cable connectors from their motherboard sockets.
    • The wires connecting to the battery are not very long, so be careful when removing them.
  7. JBL Clip 3 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the four screws that secure the motherboard.
  8. JBL Clip 3 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the motherboard away from the speaker housing.
    • Take care not to damage the soldered connections when lifting the motherboard.
  9. JBL Clip 3 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Clip 3 Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to carefully pry your way around the battery, slowly lifting it off of the epoxy until it fully releases.
    • Avoid puncturing or bending the battery. It is a Lithium cell, so there is a bit of risk involved when completing this step. Be careful and patient, and there will not be any complications.
    • During reassembly, remember to superglue the new battery back into place.
crwdns2935229:05crwdne2935229:0
Kyle Montague
crwdns2935283:003/28/22crwdne2935283:0
262 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-5, Petersen Spring 2022 crwdns2935289:0UMass Dartmouth, Team 1-5, Petersen Spring 2022crwdne2935289:0
UMASSD-PETERSEN-S22S1G5
crwdns2947412:05crwdne2947412:0
Thanks, but unless I missed something I don't see the recommended battery to replace with (only that it's a 1000mAh). Under "what you need" there's no mention of battery.
B.Bender - crwdns2934203:0crwdne2934203:0
Amazon and others sell them. Just Google "JBL Clip 3 battery for sale". Price varies widely.
CalTee -
Thank you - very helpful guide! Was able to replace my battery with no issues.
JB Zorg - crwdns2934203:0crwdne2934203:0
What can I use to create a new waterproof seal?
Seany Wheels - crwdns2934203:0crwdne2934203:0
Is this the same process as for the JBL Clip 4?
Marc Oliver - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 52
crwdns2936753:030crwdne2936753:0 185
crwdns2942667:0crwdne2942667:0 7,878
