The Clip 3 is IPX7 waterproof and offers up to 10 hours of playtime, powered by a 1000mAh rechargeable Li-ion battery. If the battery is not charging or holding adequate charge, the battery may require replacement.
This guide will show you the step by step process of replacing a speaker battery for a JBL Clip 3. The process won’t be too difficult, requiring no special skills. Make sure to be careful when removing parts on this device, because they can be fragile.
Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
Separate the speaker housing from the rest of the body.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
Lift the metal carabiner clip from the speaker housing.
I’ve looked online and can’t find a place to buy the replacement clip. Any tips?
Yea, me too. I’m glad I know how to replace it now but where do I get the part???
Agree. Showing how to replace a part when no replacment part is available is not at all helpful.
Has anyone found this part yet? I have 2 of these speakers that need a new clip!
Another option is to remove the clip altogether as it is not fixable. Works fine without it!
Use a pair of tweezers to lift the two cable connectors from their motherboard sockets.
Use a Phillips #1 screwdriver to remove the four screws that secure the motherboard.
Gently lift the motherboard away from the speaker housing.
Use an opening tool to carefully pry your way around the battery, slowly lifting it off of the epoxy until it fully releases.
crwdns2935229:05crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Thanks, but unless I missed something I don't see the recommended battery to replace with (only that it's a 1000mAh). Under "what you need" there's no mention of battery.
Amazon and others sell them. Just Google "JBL Clip 3 battery for sale". Price varies widely.
CalTee -
Thank you - very helpful guide! Was able to replace my battery with no issues.
What can I use to create a new waterproof seal?
Is this the same process as for the JBL Clip 4?
