crwdns2943259:0crwdnd2943259:0crwdnd2943259:0crwdnd2943259:0crwdne2943259:0
由于Micro USB / AUX端口连接器与白色外壳粘合牢固,因此几乎不可能在不更换整个外壳的情况下进行更换。 按照本指南分离并更换包含Micro USB / AUX端口的白色外壳。
在开始之前,请确保设备已断开电源。
在每个角落使用Jimmy或金属撬棒将外壳与设备分开。
使用PH1螺丝刀从电池盖上取下五颗6毫米十字螺丝。
取出电池盖并将其放在一边。
使用撬棒从电池和电池仓中取出大部分液态电工胶带。
This is NOT liquid Electrical tape! I recommend using 3M adhesive silicone. If you are doing this repair then you can find the 3m adhesive silicone at automotive stores. Liquid tape hardens and 3M adhesive remains mailable vs the rock hardening effect of liquid tape.
使用金属撬棒将电池从设备边缘翘出。
将电池提起足够的电池,以将其下方的16mm PH2螺丝卸下。
用PH2螺丝刀从白色塑料外壳上拆下剩下的四颗16mm十字螺丝。
The two screws on the right side (side with the USB port) are too long to extract with the iFixit screwdriver in the basic kit. I needed to use a regular thin PH2 screwdriver to get them out.
I had this problem also, whenever putting the screws back in there were still air pockets in the side with smaller screws
从一个角落开始,套管和侧面相遇。 用尖头的金属撬棒将这些接缝的胶水分开在一起。
沿着这些接缝滑动金属撬棒,将后盖与扬声器的其余部分分开。
一旦设备打开,请断开主板上的三个白色连接器。
分离两个套管。
Hi , Thanks a lot in my speacker i had broken plastic part which affect clear sound with your guide i open mine seasily and take it out now i have beand new sound which i had before. thanks again.
将注意力转移到之前拆下的套管上。
where can i get the usb port with the cable that goes to mother board and it has the thre colors red black white please give me any place where i can buy it
使用刀片,移除固定电池线缆的胶水。
竖刀切,来移除固定胶水。
When reinstalling I used E600 glue to replace this goop of glue that is removed.
拉出电池线缆周围的海绵。
从孔中穿过以移除线缆,然后移除电池。
这整个白色的部分需要被更换。(如果需要更换 AUX/USB 接口).
Why does the whole White piece need to be replaced if replacing the USB port. I just took apart the case just to replace the USB port (not the battery). It looks like I can replace the port and not need a new case.
It looks like it would be difficult removing the USB assembly because mine looked very well glued in that little space meant for the module to fit.
Thanks for this guide
I replaced the battery but it still won’t cheat fe, could the usb port be damaged and where can I purchase a usb port for my gen1 JBL Charge speaker?
打开设备,并在新的白色外壳里装入电池。
组装设备
there is only how u taking the thing a part but how to replace the usb port , to charge it again ..?
If you can struggle through all the black sealing putty and hot glue, you can remove just the charge port and cable.
Where do you get the new white casing from? It says “no parts needed” but it seems like u need an important part!
請問我的micro usb 接觸不良.,想換線組怎麼買?到哪買?
請問我的是micro usb 接觸不良無法充電,想買機板含線組更換,..不知道哪裡可以買到
按相反的步骤组装设备
按相反的步骤组装设备
crwdns2935229:014crwdne2935229:0
crwdns2934873:0crwdne2934873:0
80%
crwdns2934883:0天下有狗狗crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2944067:021crwdne2944067:0
Hi. This is the problem my speaker is having, but all I need to know is where to buy the replacement back. That's certainly something you should have included in your guide.
The purpose of a guide is to show how to fix the device, not obtain parts. I suggest eBay.
Joe Durand. Thank you for taking time out of your busy day to share such an enlightening comment.
Yeah what was the point of this if people can't actually do it. BS
The point is to guide people on the replacement of parts, not obtaining parts. I suggest eBay.
Worked like a charm. After sourcing the cable from eBay, $15 plus ship and 30 minutes of tear down and assembly.... We're in business. Important note.... Instructions do not show removal of cable from the back case but easily accomplished.
Jim, what exactly did you search on eBay? I am unable to find the casing
Rob -
Yes I'd like to know the part number for the usb cable also.
Jerome -
I love my charge. Guess I got the same problem, stupid usb charge port breaks, been tweaking the angle/pressure of the cable/plug for too long now, just to charge it. I took it apart following the procedure, Thanks! fun fun!. I'm not going to pursue replacing the whole panel and connector board, I don't see the point, its just gonna break again. I'm gonna just tap in to the charge wires inside, drill a hole, bring those outside and into something like a mini headphone socket. I'll glue that to the back of the unit or whatever. Then I'll modify a USB cable with a corresponding jack and connect just the needed + and - connections needed for charging. I'll just need to figure out where in the usb cable that charging voltage is. Not worried about that, I have my voltmeter, and the internet. I'll let you know how this goes. Drew
I swear this is stupid USB charging karma just deciding to really annoy me. why would you use an apparently fragile micro-usb connector, JUST FOR CHARGING in the first place? anyway, I happen to also own a bose soundlink color, Its a nice unit, a bit more bassy and louder than the charge, but then again with the charge bass response depends highly on location. The Bose unit doesn't have the battery life of the charge, I'mthinking around two hrs less play time on bluetooth. so anyway, since the charge is taken apart right now, was using the bose all day, then the batt died, when to plug it in, and same $@$*, now I got to fiddle with the stupid fragile usb plug just to get it to charge. I've only had this bose unit for 5 months, and it was brand new, and from experience I've been real carefull when plugging it in to charge. rediculous! now I have to learn how to takes another one appart.
dreww -
When playing music my device JBL skips..how can I correct this
V disappointed in JBL product. Great sound to go with a v poor charging mechanism. An alternative is sorely needed for these types of ports.
mines has no screws!
I would like to splice a USB cable in place of the microWhat I would like to know is what wires would I connect to what wires on USB cable to to be able to charge my unit terry-bell@live.com
Lol I am just about to splice the battery cables and feed a spliced USB cable to it haha what's the point of spending more money if its just gonna break again
You should probably add the white casing to your parts list and recommend places to buy it……..
has anyone tried charging through the full size USB port ?
Hi I have a problem with my jbl charge 2. The Bluetooth doesn't work and my Aux Port got burned by an aux cable where can I fine a notherAux Port
Left out removing black sealant over protective cover!
Afterwards remove the single screw in the center and remove circuitry
Voila no need to damage or replace the case
*Baby Genius at work here*
Chest thumpers unite!
Basically, I'm fed up with the BT quality and range with my Bose SoundLink II, and thought about getting a CC Audio to pair with it.
There's a micro-USB port on it that I thought about making a special cable for to power the CC Audio to keep the whole package portable. Anyone attempt this?
Alternatively.. Are there any CC enabled portable speakers out there? Not interested in anything with Google Assistant either.
Thanks!
Thanks! see: https:https://sarkariresult.onl/ , https://pnrstatus.vip/ & https://19216811.cam/
