JBL Charge Button Membrane Replacement
crwdns2869540:0crwdne2869540:0: 11K
4
28
116
11,076
crwdns2955950:0crwdne2955950:0: 8
crwdns2960004:06crwdne2960004:0, crwdns2960008:02crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 4
crwdns2959974:04crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:08crwdne2931287:0
This guide is intended to help fix buttons that are not functioning correctly.
    1. JBL Charge Button Membrane Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge Button Membrane Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge Button Membrane Replacement, Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Make sure the device is powered off before you begin to disassemble the speaker.
      • Remove the trim from the speaker using a jimmy or metal spudger.
    2. JBL Charge Button Membrane Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge Button Membrane Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #1 screwdriver to remove the five 6 mm screws securing the battery cover.
      • Remove the battery cover and set the cover aside.
    3. JBL Charge Button Membrane Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge Button Membrane Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Do not puncture or bend the battery. Take care not to damage the battery cable beneath the black adhesive.
      • Use a plastic spudger to carefully loosen the black adhesive securing the battery in its compartment.
      • Do not remove the battery yet—it is still connected to the speaker.
    4. JBL Charge Button Membrane Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge Button Membrane Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The first photo shows a metal spudger. Use a plastic spudger instead to avoid damaging the battery.
      • The battery is still connected to the speaker. Do not pull on the cable or attempt to remove the battery completely.
      • Use the flat end of a plastic spudger to gently lift the end of the battery opposite the cable. Lift it only far enough to access the screw underneath. Do not bend the battery or strain its cable.
      • Use a Phillips #2 screwdriver to remove the 16 mm screw beneath the battery.
    5. JBL Charge Button Membrane Replacement, Remove the remaining housing screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge Button Membrane Replacement, Remove the remaining housing screws: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #2 screwdriver to remove the four remaining 16 mm screws securing the white plastic housing.
      • Keep these screws separate from the shorter battery-cover screws.
    6. JBL Charge Button Membrane Replacement, Open the rear housing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge Button Membrane Replacement, Open the rear housing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The rear housing is still connected to the speaker by cables. Do not pull the housing halves apart.
      • Starting at the corner shown in the photos, carefully insert a metal spudger into the seam between the rear housing and the speaker.
      • Work along the seam to release the adhesive. Avoid inserting the tool deeply into the speaker, where it could damage internal components.
      • Open the rear housing only far enough to access the connectors.
    7. JBL Charge Button Membrane Replacement, Disconnect the rear housing: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge Button Membrane Replacement, Disconnect the rear housing: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Support the rear housing so that it does not hang from its cables.
      • Disconnect the three white connectors from the motherboard. Grip the connector housings rather than pulling on the wires. Do not force the connectors.
      • Remove the rear housing.
    1. JBL Charge Button Membrane Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 9 mm Phillips screw in the corner of the motherboard.
    2. JBL Charge Button Membrane Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge Button Membrane Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the motherboard from the casing by lifting the corner of the board out of the device.
      • If the motherboard won't budge, be sure that the square component on the bottom of the motherboard clears the edge of the speaker.
      • During reassembly, make sure the motherboard is fully installed and not sticking up past its original position, as this could damage the motherboard.
    3. JBL Charge Button Membrane Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the two white connectors from the bottom of the motherboard.
    4. JBL Charge Button Membrane Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge Button Membrane Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull down on the black clip holding the ribbon cable in place.
      • Pull the ribbon cable from the connector using the blue tab.
      • Remove the motherboard from the device.
    1. JBL Charge Button Membrane Replacement, Button Membrane: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the buttons on top of the device. Peel the white piece of tape located along the side of this button membrane.
    2. JBL Charge Button Membrane Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pull out the button membrane. You should not expect much resistance.
Jake Bertholf
crwdns2935283:004/01/15crwdne2935283:0
378 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-1, Lancaster Spring 2015 crwdns2935289:0Cal Poly, Team 12-1, Lancaster Spring 2015crwdne2935289:0
CPSU-LANCASTER-S15S12G1
crwdns2935297:096crwdne2935297:0
Por favor, disculpe mis errores:
"No puedo encontrar un nuevo reemplazo. Compra uno roto. Utilice el botón de la que se rompe."
Joe Durand - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 116
crwdns2959996:0crwdne2959996:0 11,076
