crwdns2937539:0crwdnd2937539:0crwdne2937539:0
If your speaker is not working or sounds like it's not delivering the high quality you expect from JBL, maybe you need to replace the battery. Replacing the battery can breathe new life into your worn device.
Make sure the device is powered off before you begin to disassemble the speaker.
Remove the trim from the speaker using a jimmy or metal spudger.
Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
Remove the battery cover and set the cover aside.
Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
Use a spudger to lift the battery out of the device.
Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
Once the back casing is open, disconnect the three white connectors from the motherboard.
Remove the upper casing.
Turn your attention to the back casing removed in Step 7.
Using a razor blade, remove the glue holding the battery cable in place.
Use multiple vertical cuts to remove pieces of the glue.
Remove the foam surrounding the battery cable.
To remove the battery, pull the battery cable through the hole.
crwdns2935229:037crwdne2935229:0
crwdns2944067:032crwdne2944067:0
How i replaced a new battery in myjbl reflect headphone bluetooth
Please I need directions on replacing the battery of my jbl pulse speaker because it charges but doesn't indicate battery charging nor does it work.please I will be ver grateful.
Ifeanyi(kazhbone0147@gmail.com)
I need help.
My speaker no longer takes a charge.
Not even that old
Where do I get replacement battery. And what kind
Rose -
Your instructions state to replace the white cover, but do not say why it has to be replaced. Can you expound, please? Thank you,
Hi Delton, that is a good question. The entire cover has to be replaced if one is replacing the aux/USB ports.
You can ignore that note in this battery replacement guide. Good catch!
