JBL Charge Battery Replacement
crwdns2869540:0crwdne2869540:0: 24만
13
122
588
241,524
crwdns2955950:0crwdne2955950:0: 45
crwdns2960004:010crwdne2960004:0, crwdns2960008:035crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 40
crwdns2959974:040crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 4
crwdns2959982:04crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:010crwdne2931287:0
Use this guide to replace the battery in your JBL Charge. Compare your speaker with the photos before you begin.
A worn battery may cause significantly reduced playback time. Failure to power on or poor sound quality can have other causes, so check the power supply and symptoms before replacing the battery.
Before starting, reduce the battery charge below 25% if the speaker still works and the battery shows no signs of damage. Turn off the speaker and disconnect all cables.
If the battery is swollen or damaged, do not proceed with this guide as written.
Do not puncture, bend, or crush the battery. Use a plastic spudger when working directly against the battery. The battery remains connected during the initial disassembly steps.
    1. JBL Charge Battery Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge Battery Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge Battery Replacement, Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Make sure the device is powered off before you begin to disassemble the speaker.
      • Remove the trim from the speaker using a jimmy or metal spudger.
    2. JBL Charge Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #1 screwdriver to remove the five 6 mm screws securing the battery cover.
      • Remove the battery cover and set the cover aside.
    3. JBL Charge Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Do not puncture or bend the battery. Take care not to damage the battery cable beneath the black adhesive.
      • Use a plastic spudger to carefully loosen the black adhesive securing the battery in its compartment.
      • Do not remove the battery yet—it is still connected to the speaker.
    4. JBL Charge Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The first photo shows a metal spudger. Use a plastic spudger instead to avoid damaging the battery.
      • The battery is still connected to the speaker. Do not pull on the cable or attempt to remove the battery completely.
      • Use the flat end of a plastic spudger to gently lift the end of the battery opposite the cable. Lift it only far enough to access the screw underneath. Do not bend the battery or strain its cable.
      • Use a Phillips #2 screwdriver to remove the 16 mm screw beneath the battery.
    5. JBL Charge Battery Replacement, Remove the remaining housing screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge Battery Replacement, Remove the remaining housing screws: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #2 screwdriver to remove the four remaining 16 mm screws securing the white plastic housing.
      • Keep these screws separate from the shorter battery-cover screws.
    6. JBL Charge Battery Replacement, Open the rear housing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge Battery Replacement, Open the rear housing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The rear housing is still connected to the speaker by cables. Do not pull the housing halves apart.
      • Starting at the corner shown in the photos, carefully insert a metal spudger into the seam between the rear housing and the speaker.
      • Work along the seam to release the adhesive. Avoid inserting the tool deeply into the speaker, where it could damage internal components.
      • Open the rear housing only far enough to access the connectors.
    7. JBL Charge Battery Replacement, Disconnect the rear housing: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge Battery Replacement, Disconnect the rear housing: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Support the rear housing so that it does not hang from its cables.
      • Disconnect the three white connectors from the motherboard. Grip the connector housings rather than pulling on the wires. Do not force the connectors.
      • Remove the rear housing.
    1. JBL Charge Battery Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the rear housing on your work surface with its inner side facing up.
      • Locate the battery cable and the opening through which it passes.
    2. JBL Charge Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a razor blade, remove the glue holding the battery cable in place.
      • Use multiple vertical cuts to remove pieces of the glue.
      • The blade can damage the battery cable insulation and cause a short circuit. Do not cut into the cable or work where the cable is hidden beneath the adhesive. If you cannot clearly see and avoid the cable, stop.
    3. JBL Charge Battery Replacement, Remove the foam: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully remove the foam surrounding the battery cable.
      • Do not pull on the cable or damage its insulation.
    4. JBL Charge Battery Replacement, Remove the battery: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully guide the disconnected battery connector and cable through the opening in the housing.
      • Do not force the connector through the opening or pull on the wires.
      • Remove the battery.
crwdns2935229:040crwdne2935229:0
Joe Durand
crwdns2935283:004/01/15crwdne2935283:0
2,313 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-4, Lancaster Spring 2015 crwdns2935289:0Cal Poly, Team 12-4, Lancaster Spring 2015crwdne2935289:0
CPSU-LANCASTER-S15S12G4
crwdns2935297:048crwdne2935297:0
crwdns2947412:035crwdne2947412:0
How i replaced a new battery in myjbl reflect headphone bluetooth
Mohamad Lutfi - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Please I need directions on replacing the battery of my jbl pulse speaker because it charges but doesn't indicate battery charging nor does it work.please I will be ver grateful.
Ifeanyi(kazhbone0147@gmail.com)
Ifeanyi Anaetoh - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I need help.
My speaker no longer takes a charge.
Not even that old
Where do I get replacement battery. And what kind
Rose - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Your instructions state to replace the white cover, but do not say why it has to be replaced. Can you expound, please? Thank you,
Delton Eason Jr - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi Delton, that is a good question. The entire cover has to be replaced if one is replacing the aux/USB ports.
You can ignore that note in this battery replacement guide. Good catch!
Joe Durand - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 122
crwdns2936753:030crwdne2936753:0 588
crwdns2959996:0crwdne2959996:0 241,524
