JBL Charge 5 Speakers Replacement
  1. JBL Charge 5 Speakers Replacement, Fabric Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Speakers Replacement, Fabric Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Speakers Replacement, Fabric Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Ensure that the device is fully powered off and no cables are attached before proceeding with the repair.
    • This fabric cover is secured with plastic clips only. Depending on the model, the cover may be secured by both plastic clips and screws.
    • Insert the flat end of the Jimmy into the seam located between the fabric cover on the right side of the seam.
    • Pry upward on the fabric cover to release plastic clips on the right side of the seam.
  2. JBL Charge 5 Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Speakers Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Speakers Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of the Jimmy into the seam between the fabric cover at the center of the seam and the left side of the seam.
    • Use the Jimmy to pry open the edge with the rubber texture, releasing the remaining plastic clips.
  3. JBL Charge 5 Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Speakers Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Speakers Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hands to gently open the two halves of the casing and slide the fabric cover off of the interior housing.
  4. JBL Charge 5 Speakers Replacement, Speakers: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Speakers Replacement, Speakers: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Speakers Replacement, Speakers: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the four 16.5 mm screws on the corners around the oval speaker.
  5. JBL Charge 5 Speakers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Speakers Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Speakers Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently use your hands to undo the flaps located at the top of the speaker.
    • Grip the speaker on the top and bottom left of the square platform.
    • Gently remove the speaker from the casing.
    • Be careful of the wires attached to the back of the speaker when removing.
  6. JBL Charge 5 Speakers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Speakers Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Speakers Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Holding the speaker firmly in place, gently remove the red wire from the speaker by pinching it at the silver base near the connection and pulling.
  7. JBL Charge 5 Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge 5 Speakers Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous step for the black wire.
  8. JBL Charge 5 Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Speakers Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Speakers Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the two 16.5 mm screws in the small round speaker's top right and bottom left corners.
    • Gently use your hands to grip the speaker and remove it from the device.
  9. JBL Charge 5 Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge 5 Speakers Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the white wire gently at the silver base near the connection.
    • Carefully disconnect the wire from the speaker by pulling it.
  10. JBL Charge 5 Speakers Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge 5 Speakers Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous steps for the black wire.
    • Both speakers should be properly detached.
Kat Whaley
crwdns2935283:009/13/23crwdne2935283:0
870 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-2, Virtue Fall 2023 crwdns2935289:0Western Carolina University, Team 1-2, Virtue Fall 2023crwdne2935289:0
WCU-VIRTUE-F23S1G2
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 47
crwdns2936753:030crwdne2936753:0 210
crwdns2942667:0crwdne2942667:0 3,203
