crwdns2959928:0crwdne2959928:0 ↓Sometimes the button switches on your JBL Charge 3 can wear out or get dirt in them causing one or more buttons to not work. Luckily the buttons are easy to clean once the cover is removed.
Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
Repeat this process for all four edges of the front cover.
Pull apart your cover gently from both sides and remove it from the speaker housing.
Use your plastic opening tool to pry around the edges of the button cover. This will begin to separate the adhesive from the cover.
Peel away the button cover with your hand once you have enough separated from the speaker housing to grab.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Flip open the top flap on the ZIF connector.
Gently pull out the ZIF connector cable with tweezers.
crwdns2935229:017crwdne2935229:0
my jbl dont turn on even its in charge it wont turn on
batteries are new but still wont wor
D- ASTRO - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where do i buy new buttons?
Thomas Bjerregaard - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Could you please provide info about where to get the green board?
Alvaro Pérez Morales - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Next steps are missing.
5.) What happens after the disconnecting the ZIF?
6.) a.) How do you remove the button board? Is that what needs to then be replaced?)
6.) b) Or do I need soldiering skills and learn to attach new buttons to the existing board.
Happy to learn - hoping to be pointed in the right direction...
Mark Freeman - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
