How to disassemble the JBL Charge 2 for replacing speakers.
Remove the screen cover from the speaker using a metal spudger.
Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
Remove the end cap of the device. Repeat the same process to remove the other end cap.
To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
Twist off the end cap and remove them from the device.
Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
Pry away the plastic battery cover with a plastic spudger.
Disconnect the battery connector with a plastic opening tool and wiggle the connector free.
Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
Slide the battery free.
Remove the opposite screen cover using a metal spudger
Use the Phillips #1 screwdriver (PH1) to remove the (8) eight screws.
Pull out the speakers from the device.
Disconnect the wiring from the speaker by using the fine tip pry tool.
Remove the speakers from the device.
