This guide can be used to replace your USB ports and aux cable.
Flip the device so the bottom is facing you.
Remove the bottom pad with a nylon or metal spudger.
Remove the 4 screws that hold the white cover.
Remove the one screw holding the circuit board.
Pry the board with the plastic opening tool.
Slide the ribbon gently out of the connector.
crwdns2935229:017crwdne2935229:0
crwdns2944067:015crwdne2944067:0
Hi! I need the mini usb piece but I don´t know were I can buy it, it is not like the mobile one´s! Please help me!
Thanks
Just having the same issue with the internally broken micro-usb connector. Is it standard, or something special? Thanks!
I think it is not normal, if you can find it please contact me! Thanks
I also need to replace my usb connector, has anyone found out where to get one?
need the micro-usb aswell
