Ivation IVWPDC20Y Display Replacement
  1. Ivation IVWPDC20Y Display Replacement, Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
  2. Ivation IVWPDC20Y Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a plastic opening tool to each of the corners and gently remove the casing
    • The front casing is held down by adhesive and may require additional work to remove
    • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
  3. Ivation IVWPDC20Y Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five silver screws from the inner casing using the PH00 screwdriver bit.
  4. Ivation IVWPDC20Y Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit.
    • These screws are very small and easy to strip so apply consistent pressure when removing them
  5. Ivation IVWPDC20Y Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off back outer casing using the black spudger or the blue prying tools.
  6. Ivation IVWPDC20Y Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the screen from the silver casing using a prying tool or the black spudger.
    • There is adhesive in the center of the screen, be sure not to bend it when applying pressure.
  7. Ivation IVWPDC20Y Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the poker end of the spudger push gently on the black pegs holding the orange tape in place.
    • Screen and orange tape should slip out as a whole.
Alex
crwdns2935283:002/08/16crwdne2935283:0
228 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 6-6, Eyestone Spring 2016 crwdns2935289:0USF Tampa, Team 6-6, Eyestone Spring 2016crwdne2935289:0
USFT-EYESTONE-S16S6G6
crwdns2942667:0crwdne2942667:0 424
