Irest SL A28-1 Massage Chair Jerking Bump Fix
  1. Irest SL A28-1 Massage Chair Jerking Bump Fix, Which chair is it ?: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The chair is one like this.
  2. Irest SL A28-1 Massage Chair Jerking Bump Fix, How to open the chair: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Irest SL A28-1 Massage Chair Jerking Bump Fix, How to open the chair: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Irest SL A28-1 Massage Chair Jerking Bump Fix, How to open the chair: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fold backrest forward by pressing the release tab in and under the chair (Arrowed) and push the backrest forward.
    • On the two last pictures you can see the release lock and tap after the backrest is folded forward
  3. Irest SL A28-1 Massage Chair Jerking Bump Fix, Remove the screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Irest SL A28-1 Massage Chair Jerking Bump Fix, Remove the screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw for the cord inlet (Marked as 1) and remove the cord cover
    • Remove the 5 screws (marked 2) for the back cover - Please note they are NOT all the same size, so pay attention to the positions
  4. Irest SL A28-1 Massage Chair Jerking Bump Fix, Remove the cord and back cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the cord cover (#1 in previous step) removed, remove the two connectors
    • The connectors on my model was protected with plastic strips to prevent me from releasing the lock tap - didn't work - I took the picture AFTER I had removed the cover so it was easier to see what the connectors looked like
    • Remove the strips or pull them towards the wires (Upwards) and use a flathead screwdriver to prise the lock open and remove the connector
    • Remove the back cover
  5. Irest SL A28-1 Massage Chair Jerking Bump Fix, Why was there a jerky bump ?: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In my case I looked at the mechanism and saw no immediate failures
    • I then noticed that a black strap (Arrowed) was showing signs of being curled/crumbled
    • Further examination shows that the strap, which goes from top to bottom, was not aligned 100 % centered between the massage wheels (I try to show that with the red line) and the strap had become a little loose
    • The result was the that the right wheel was sort of "picking up" the strap, so both wheels was on the same side of the strap
    • At some point the right massage wheel had to cross back again over the strap hereby crumbling it and giving this jerky bump.
  6. Irest SL A28-1 Massage Chair Jerking Bump Fix, Fix the issue - tighten and move the strap a little: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Irest SL A28-1 Massage Chair Jerking Bump Fix, Fix the issue - tighten and move the strap a little: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The fix is to tighten the strap - there are two ways
    • 1 - Remove the frame with wheels and rollers and re-align + tighten the strap
    • 2 - Tighten and partly re-align the strap
    • I opted for solution 2
    • I tightened the strap at the botton of the frame, because this is where I had space to manouvre
    • I positioned the strap more to the left so it got centered
    • I used a 1.5 mm drill to prepare a whole in the frame so the plate screw (See picture 2) does not rapture the woodden frame
    • I used a plate screw to secure the strap in the new position
To reassemble your device, re-connect the cable connectors
Then place the back cover again, making sure it fits without pinching something
Finally place the cable/cord cover
Jan Carsten Jorgensen
crwdns2935283:002/28/16crwdne2935283:0
1,118 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 717
