If your record/stop switch is not working follow this guide to replace it.
Remove the six screws (3 mm) that secure the lens cover bezel with a #00 Phillips screwdriver.
Remove the blue securing the lens cover. Then simply pull off the lens cover itself.
Remove black aluminum casing as shown.
Using a #00 Phillips screwdriver, unscrew the screw securing the record/stop switch.
Remove the record/stop switch. You are then able to replace the switch.
