This step is one of the longest steps to complete yet it is essential in order to replace the body cover. If the Ion Air Pro is unable to be mounted on because the body cover is damaged, the body cover will have to be replaced. Follow these steps carefully on how to remove the body cover.
After you're done with unscrewing, take off the blue lid shown here.
On the other side of the device, lift this black piece of cover that is underneath the cap, on the bottom side of the Ion Air Pro.
After removing the black lid, unscrew all eight screws here.
Remove two more screws, one on each side, inside this socket.
Next, unscrew the two screws located here.
Detach the bottom black piece off from the bottom side but do not disconnect it from the wires.
Finally, you can remove the body cover off and replace it with a new one if you have to.
Im struggling to get this final blue housing to remove,
Any advice if possible?
crwdns2947412:05crwdne2947412:0
Hey Chris where can I buy a replacement body cover?
The thread of the screw socket on my ion air pro WiFi has worn out and it can no longer be screwed onto any mounts.
I LOST THE LOSTTHE REAR COVER WHILE HUNTING. iS THERE A REPLACEMENT I CAN GET
i lost the rear cover cap while hunting. can i purchase a new one
Can you show a photo of the other side (compared to step 8) showing the mounting thread please?
Help: How to replace the battery, mine won't charge?
