Iomega Z100S2 Motherboard Replacement
  1. Iomega Z100S2 Motherboard Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Iomega Z100S2 Motherboard Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
  2. Iomega Z100S2 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Move down the same side and push in the plastic tab.
  3. Iomega Z100S2 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Move to the front right side and once again push in the plastic tab.
    • There is not a fourth tab to push in after this one.
  4. Iomega Z100S2 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Iomega Z100S2 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the cover by the front side and pull upwards.
    • You might encounter some resistance. Pull firmly, but don't yank it.
  5. Iomega Z100S2 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Iomega Z100S2 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tilt the front case down until the pegs detach from the bottom of the case.
    • Lift up and outward.
    • The motherboard will be loose at this point.
    Easy button and status light repair:
    button and plastic piece both need just 2 tiny drops of super glue.
    Donald Fournier - crwdns2934203:0crwdne2934203:0
  6. Iomega Z100S2 Motherboard Replacement, Disk Reader: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Iomega Z100S2 Motherboard Replacement, Disk Reader: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unhook the two springs from the front plastic hooks.
    • The black side rails of the reader should easily slide forward and off.
  7. Iomega Z100S2 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There is a white tab connected to the motherboard. Pull it upward by gently rocking it back and forth.
    • The tab does not come completely out, it only slides up slightly, so don't rip it out!
  8. Iomega Z100S2 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Iomega Z100S2 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the reader by its sides and gently pull it upward.
    • There are two wires still connected to the bottom of the reader that haven't been detached.
  9. Iomega Z100S2 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the white wires by using tweezers to gently pull the bottom connector toward you.
  10. Iomega Z100S2 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Iomega Z100S2 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the thin ribbon wire by using tweezers to gently pull the connector at the bottom toward you.
  11. Iomega Z100S2 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the reader up and out from the device.
  12. Iomega Z100S2 Motherboard Replacement, Motherboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Iomega Z100S2 Motherboard Replacement, Motherboard: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T6 Torx Screwdriver to remove the 1.3 mm screw at the back of the motherboard.
  13. Iomega Z100S2 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Iomega Z100S2 Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the motherboard and back case out from the bottom case.
Ezery Kennedy
crwdns2935283:010/05/10crwdne2935283:0
288 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-53, Amido Fall 2010 crwdns2935289:0Cal Poly, Team 7-53, Amido Fall 2010crwdne2935289:0
CPSU-AMIDO-F10S7G53
how to fix the motherboard if booth leds stay lit when powering up?
ACIDGREEN TECHNO - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 3,565
