This guide details the steps to take off the button pad of your Inter-tel IP 8660.
Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
8 mm long
11 mm long
Lift up the back cover and set it aside.
While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
Lift up the motherboard and set aside
Remove all plastic buttons. (Note: Look at the initial picture for locations of each button set)
