Intel NUC11TNKi5 CPU Fan Replacement
  1. Intel NUC11TNKi5 CPU Fan Replacement, Remove back-plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew 4 screws located in corners of back-plate.
    • Remove the back-plate.
  2. Intel NUC11TNKi5 CPU Fan Replacement, Remove NVME module: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the screw holding the NVME module.
    • Remove the NVME module, so there is an access to WiFi module.
  3. Intel NUC11TNKi5 CPU Fan Replacement, Unplug wires: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug WiFi antenna pigtails. Lift them carefully.
    • Unplug the RTC/CMOS battery header. Be aware, that BIOS settings will be erased immediately and need to be restored manually, once NUC is power on again.
  4. Intel NUC11TNKi5 CPU Fan Replacement, Unscrew board screw: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew 2 board screws.
  5. Intel NUC11TNKi5 CPU Fan Replacement, Remove top cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert spudger tool inside the top cover opening area and lift the top cover and remove it.
  6. Intel NUC11TNKi5 CPU Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew 6 screws from the top.
  7. Intel NUC11TNKi5 CPU Fan Replacement, Remove motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Intel NUC11TNKi5 CPU Fan Replacement, Remove motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now, the motherboard can be removed by pulling the B-Key SATA screw lock.
  8. Intel NUC11TNKi5 CPU Fan Replacement, Remove the fan: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew 2 screws holding the fan.
    • Unplug wires from the motherboard.
    • Remove the fan.
  9. Intel NUC11TNKi5 CPU Fan Replacement, Remove the fan passive block: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Intel NUC11TNKi5 CPU Fan Replacement, Remove the fan passive block: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew 4 screws holding the fan passive block.
    • Remove the passive block. Be aware there is a thermal paste below.
  10. Intel NUC11TNKi5 CPU Fan Replacement, Clean old thermal paste: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Intel NUC11TNKi5 CPU Fan Replacement, Clean old thermal paste: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Intel NUC11TNKi5 CPU Fan Replacement, Clean old thermal paste: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply isopropyl alcohol (at least 90% purity) to cotton swabs.
    • Remove the old thermal paste form chips by using cotton swabs. Repeat cleaning until all paste is removed.
    • Remove the old thermal paste form passive block by using cotton swabs. Repeat cleaning until all paste is removed.
  11. Intel NUC11TNKi5 CPU Fan Replacement, Apply new thermal paste: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply new thermal paste on marked chips. Use small amount of paste and spread it with a firm paper. Do not apply any thermal paste on passive block.
  12. Intel NUC11TNKi5 CPU Fan Replacement, Put back the fan passive block: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully, put back the passive block.
    • Screw 4 screws.
  13. Intel NUC11TNKi5 CPU Fan Replacement, Put back the fan: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put back the fan.
    • Screw 2 screws.
    • Plug fan wires to the motherboard.
    • Apply electrical tape on fan, so it's firmly attached to the fan as well as to the passive block.
  14. Intel NUC11TNKi5 CPU Fan Replacement, Reassemble NUC: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To reassemble your NUC, follow disassembling instructions in reverse order.
    • When you first run the NUC, the BIOS settings and time settings have gone because battery was unplugged. Therefore, enter the BIOS and save the settings you would like to use. Don't forget to check the fan speed and its settings!
vookimedlo
crwdns2935283:005/04/12crwdne2935283:0
259 crwdns2915208:0crwdne2915208:0
Pretty sure not all of those screws need to be removed from the top, but there doesn't seem to be any harm either. I also don't think the RTC power needed to be disconnected?
Is there a trick to getting those antenna cables back in? They were the most annoying part of reassembly by far.
Minic - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 103
crwdns2942667:0crwdne2942667:0 966
