The plastic base covers the electronic components inside the instant pot. Before you can touch anything inside of the device the base must be removed.
            Take off the lid of the Instant Pot. Grasp the handle and rotate the lid counter-clockwise, then lift up to separate the lid from the base.
            Take out the inner pot and place it somewhere out of the way.
            Flip the Instant Pot over on its top so that the base is facing upward.
            Remove the single 12mm Phillips #2 screw holding the base to the device.
            Rotate the base counter-clockwise, then gently lift the base off of the device.
crwdns2947412:014crwdne2947412:0
Hi, I would like to know, where can I buy a new plastic base? Thank you
Hello where can I buy the plastic base
I would like to buy one of these for an 8 Qt model….very hard to source this and terrible customer support as this seems to be a issue for many that burned theirs.
Did you ever find out where you can buy this part.
Thank you. Belinda
Do you carry the replacement for this. Thanks
