Instant Pot Smart-60 Disassembly
  1. Instant Pot Smart-60 Disassembly, Bottom access plate screw: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Bottom access plate screw: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Bottom access plate screw: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert wisdom here.
  2. Instant Pot Smart-60 Disassembly, Bottom bracket - remove battery holder, then 3x bolts: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Bottom bracket - remove battery holder, then 3x bolts: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Bottom bracket - remove battery holder, then 3x bolts: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 3x bolts
  3. Instant Pot Smart-60 Disassembly, Bottom bracket - snap out power receptacle: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Bottom bracket - snap out power receptacle: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Bottom bracket - snap out power receptacle: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  4. Instant Pot Smart-60 Disassembly, Circuit board 1: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Circuit board 1: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Circuit board 1: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Black molex connector on top right must come out to remove the outer shell.
    • Red wire spring clips with blue translucent covers I was unable to remove safely, I suggest removing other ends of those wires if you need to remove the heating element plate.
  5. Instant Pot Smart-60 Disassembly, Battery and front panel wires: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Battery and front panel wires: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Battery and front panel wires: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • I needed small needle nose pliers to pinch and remove wide front panel connector.
  6. Instant Pot Smart-60 Disassembly, Outer shell ground wire: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Outer shell ground wire: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Outer shell ground wire: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  7. Instant Pot Smart-60 Disassembly, Outer shell removal - release tape from lid sensor wire: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Outer shell removal - release tape from lid sensor wire: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Outer shell removal - release tape from lid sensor wire: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  8. Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire notch: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire notch: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire notch: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • I'm skipping removing heating element and nearby sensors, it's similar to other models. Search for Instant Pot repair videos for instructions.
  9. Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire goes into notch: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire goes into notch: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire goes into notch: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  10. Instant Pot Smart-60 Disassembly, Outer shell re-assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Instant Pot Smart-60 Disassembly, Outer shell re-assembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull lid sensor wire up, re-tape to inside of outer shell.
    • Battery replacement, you should remove the screw and pull the mini circuit board holding the battery before attempting to swap batteries.
crwdns2935229:08crwdne2935229:0
Zen1
crwdns2935283:003/01/18crwdne2935283:0
392 crwdns2915208:0crwdne2915208:0
If the outer shell is dented but panel is functioning is it safe to operate the instant pot? looks like it moved a bit in the box in shipment, no visible damage to the pot just the to the aluminum shell
Jeff Medlin - crwdns2934203:0crwdne2934203:0
Mine is dented and it should be totally fine. As you said, the pressure vessel is separate from the outer shell, so there are no safety concerns. Just asthetic. I wish there wasn't this gap of air between the pressure vessel and the outer shell, or, I wish the shell was a bit more durable as it's VERY easily dented.
Kuake Ye - crwdns2934203:0crwdne2934203:0
What is the voltage of the component named ZNR091
Yanni Koulandris - crwdns2934203:0crwdne2934203:0
I recently used and cleaned my instant pot. After cleaning I found a small spring in the sink. I am wondering if it came from the pot. I have looked at dozens of diagrams and do not see a spring. What are you opinions, safe to use, not safe. Any thoughts ?
Dave - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 94
crwdns2942667:0crwdne2942667:0 9,503
