Instant Pot IP-DUO80 V2 LED Display Replacement
  1. Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the lid by turning it counter-clockwise and lifting up.
    • Remove the inner pot.
  2. Instant Pot IP-DUO80 V2 LED Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Instant Pot IP-DUO80 V2 LED Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Instant Pot IP-DUO80 V2 LED Display Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the Instant Pot upside down.
    • Remove the single 12-mm screw by using the T-15 head screwdriver and turning it counter-clockwise.
    • Turn the plate counter-clockwise and lift it off the Instant Pot.
  3. Instant Pot IP-DUO80 V2 LED Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Instant Pot IP-DUO80 V2 LED Display Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 19-mm screws in the black plastic base's edge using the PH-1 head screwdriver and twisting counter-clockwise.
  4. Instant Pot IP-DUO80 V2 LED Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Instant Pot IP-DUO80 V2 LED Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the power cord out of its slot.
    • Pull up on the edge of the black plastic base to remove the base.
    Tengo una olla Instant por necesito repararla está con golpe
    sonialrodriguezv - crwdns2934203:0crwdne2934203:0
  5. Instant Pot IP-DUO80 V2 LED Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Instant Pot IP-DUO80 V2 LED Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Instant Pot IP-DUO80 V2 LED Display Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the two green-striped yellow wires that are connected onto the bottom of the heating element. Use a PH-1 head screwdriver and turn counter-clockwise to remove the 10-mm screw holding them in place.
    • Be careful not to lose the small washer that comes with this screw.
    • Pull up on the cn101 connection to detach the LED display from the motherboard.
  6. Instant Pot IP-DUO80 V2 LED Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the silver outer shell off of the top black ring.
  7. Instant Pot IP-DUO80 V2 LED Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Instant Pot IP-DUO80 V2 LED Display Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Instant Pot IP-DUO80 V2 LED Display Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 10-mm screws connecting the LED display to the outer shell using a PH-1 head screwdriver and twisting counter clockwise.
    • Pull out the LED display by pulling on it gently.
    You say no parts? But I don’t see how you rectified the issue just by removing the LED display. Do you need a replacement LED display?
    bryonkarren - crwdns2934203:0crwdne2934203:0
    Okay..took instant pot apart as shown..do I need to buy a new led display..if so, where? Or do I just reinstall the old one?
    g locke - crwdns2934203:0crwdne2934203:0
Kayla Meacham
crwdns2935283:001/23/18crwdne2935283:0
646 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G2, Livingston Winter 2018 crwdns2935289:0Cal Poly, Team S18-G2, Livingston Winter 2018crwdne2935289:0
CPSU-LIVINGSTON-W18S18G2
Where can I get the replacement for the display?
Starfish Doodle - crwdns2934203:0crwdne2934203:0
Hola disculpa, donde puedo conseguir la pantalla led de mi instat pot DUO PLUS MULTI-COOKER 9in 1
Evaristo - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 66
crwdns2942667:0crwdne2942667:0 7,301
