How to replace the float valve on the Instant Pot IP-DUO. This procedure and part is the same for the following models: IP-DUO50, IP-DUO60, and the IP-DUO80.
Remove the lid by twisting it counter-clockwise.
Place the lid upside down on a stable surface.
Remove the white rubber cover from the red float valve by pulling it off gently.
On my model, the metal housing broke off, looks like it will need to be welded back together to the lid.
my float valve rubber is missing what can i do???how i can oder this how m gonna fix it kindly answer
How do you remove the house that the pin goes into? Mine has corrosion on the pin and inside that housing.
