Inspiron 7359 2-in-1 Screen Replacement
  1. Inspiron 7359 2-in-1 Screen Replacement, Bottom Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Inspiron 7359 2-in-1 Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger or opening pick, carefully pry in between the screen and the screen backing.
    • After opening the LCD Screen, slowly and carefully open the laptop so the front of the screen touches the keyboard.
  6. Inspiron 7359 2-in-1 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly peel back the tape that is attached to the screen itself.
    • Once the tape is removed, gently disconnect the attached cables.
  7. Inspiron 7359 2-in-1 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully disconnect the attached cable.
    • Once you remove the attached cable, gently lift up the LCD panel.
Dominique
crwdns2935283:008/26/19crwdne2935283:0
251 crwdns2915208:0crwdne2915208:0
Gateway, Team S1-G3, Saknee Fall 2019 crwdns2935289:0Gateway, Team S1-G3, Saknee Fall 2019crwdne2935289:0
GCC-SAKNEE-F19S1G3
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 518
