Inspiron 7359 2-in-1 Fan Replacement
  1. Inspiron 7359 2-in-1 Fan Replacement, Bottom Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Inspiron 7359 2-in-1 Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 Fan Replacement, Hard Disk Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew three 3mm screws with a Phillips #0 screwdriver and remove them.
    • These screws hold the hdd and removing these screws will make it easier to remove it.
  6. Inspiron 7359 2-in-1 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Inspiron 7359 2-in-1 Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the hard drive from the left side. Be careful not pull on it.
    • Pull the SATA cable that's connect to the hard drive and then carefully place the cable on the side.
  7. Inspiron 7359 2-in-1 Fan Replacement, Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Inspiron 7359 2-in-1 Fan Replacement, Fan: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the fan adapter labelled one.
  8. Inspiron 7359 2-in-1 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the wire from the hook to make it easier to take the whole fan out.
  9. Inspiron 7359 2-in-1 Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 5mm screw using the Phillips screw.
    • After the screw is extracted use your hands and carefully take the fan out.
Dominique
crwdns2935283:008/26/19crwdne2935283:0
251 crwdns2915208:0crwdne2915208:0
Gateway, Team S1-G3, Saknee Fall 2019 crwdns2935289:0Gateway, Team S1-G3, Saknee Fall 2019crwdne2935289:0
GCC-SAKNEE-F19S1G3
crwdns2942667:0crwdne2942667:0 570
