Inspiron 7359 2-in-1 Battery Replacement
  1. Inspiron 7359 2-in-1 Battery Replacement, Bottom Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Inspiron 7359 2-in-1 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew two 8mm screws with a Phillips #0 screwdriver.
    • Unscrew one silver, wide-head, 8mm screw with a Phillips #0 screwdriver.
    • Disconnect the battery cable from the motherboard.
    • Make sure to keep all screws together and label where you unscrewed them from.
  6. Inspiron 7359 2-in-1 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the old battery, lift from the bottom and pull the battery towards you.
To reassemble your device, follow these instructions in reverse order using a new battery.
Alfredo Acosta
crwdns2935283:008/26/19crwdne2935283:0
141 crwdns2915208:0crwdne2915208:0
Gateway, Team S1-G3, Saknee Fall 2019 crwdns2935289:0Gateway, Team S1-G3, Saknee Fall 2019crwdne2935289:0
GCC-SAKNEE-F19S1G3
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 199
