Insignia Sport NS-4V17 Motherboard Replacement
  1. Insignia Sport NS-4V17 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Insignia Sport NS-4V17 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia Sport NS-4V17 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Insignia Sport NS-4V17 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Insignia Sport NS-4V17 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
  5. Insignia Sport NS-4V17 Motherboard Replacement, Front Case Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia Sport NS-4V17 Motherboard Replacement, Front Case Cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  6. Insignia Sport NS-4V17 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
  7. Insignia Sport NS-4V17 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Insignia Sport NS-4V17 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Insignia Sport NS-4V17 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully wedge the plastic opening tool into either long side of the device.
    • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
    • Repeat these steps on the other side of the device.
  8. Insignia Sport NS-4V17 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
  9. Insignia Sport NS-4V17 Motherboard Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the white plastic ring from around the scroll wheel with your fingers.
  10. Insignia Sport NS-4V17 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the sides of the device firmly with one hand.
    • Push down on the black favorite switch with your other hand so that it is pushed into the case.
  11. Insignia Sport NS-4V17 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia Sport NS-4V17 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the component pushed in, lift up the top of the motherboard from the case.
    • Pull the motherboard from the top so that the audio jack and usb input are removed from the case socket.
Wesley Ballar
crwdns2935283:004/18/13crwdne2935283:0
88 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-36, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 12-36, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S12G36
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 577
