This guide will take you through the process of replacing the power cord of the Insignia NS-HTMC01-B.
Flip the device over so the back panel faces up.
Unscrew the four screws counter-clockwise from the back panel using a 4mm Phillips screwdriver.
Take the screws out and set them aside.
Gently pull the front panel and back panel apart to open the device.
Use a Phillips #2 screwdriver to remove the two 1.7mm screws from the white triangular piece covering the power cord.
Disconnect all of the blue wires. There should be 3 separate blue-wire connections.
Disconnect the second black wire from the rectangular piece above the Tip-Over Safety Switch.
Remove power cord.
