This guide will help you replace a broken or damaged power button on the outside of the Insignia NS-HTMC01-B ceramic heater. A broken or damaged power button can prevent your heater from shutting off, or turning on.
Flip your device over so the bottom panel faces you. You should see a hole containing a screw in each corner of the device.
Insert a 4-inch Phillips #1 screwdriver into each hole until connected with the 20 millimeter, sharp-point screw.
Find the power switch, located inside the heater on the bottom left corner.
Using a Phillips #1 screwdriver, unscrew the two 7 millimeter screws attaching the power switch to the power button.
Find the clips holding the power button in place.
Press down on the clips to remove the button.
