The motherboard is connected to the LCD screen and daughterboard. It is important to unscrew and disconnect the LCD and daughterboard before removing the motherboard so as not to damage these components.
Be sure the radio is turned off by pressing the red power button.
Or, if using the charger, remove the power cord.
Remove the panel on the back side of the radio by pressing the arrow in a downward motion.
Remove the batteries one-by-one by pulling from the positive terminal of the top left battery.
Remove the adjacent battery by simply pulling it out of the holder.
Repeat for the bottom row of batteries.
Using the J1 Philip's head screwdriver, remove the 4 screws from the back side of the radio.
Using the metal spudger, pry open the panel with the metal spudger. Work you way around the whole device.
Using the pliers, separate the wire connector above the left speaker.
Using the J1 Philip's head screwdriver, unscrew the bolt attaching the antenna to the back panel.
Using the J1 Philip's head screwdriver, remove the 6 screws holding the central circuit board and the upper right circuit board to the panel.
Using needle nose pliers or regular pliers, disconnect the wire connector with the red and black wires on the mother board by grabbing the end of the wires.
Using the needle nose pliers or regular pliers, separate the wire connectors attaching the speakers to the circuit board on its right and left side.
Using the needle nose pliers or regular pliers, remove the wire connector with the brown and pink wires to separate the small circuit board from the larger circuit board.
Loosen the circuit board by lifting it up.
Remove the LCD Screen by pulling the black guard away from the LCD screen with a plastic spudger.
Use the plastic spudger to lift up the top side of the LCD screen.
Lift the LCD screen up together with the circuit board.
Hi Josh, It seems like the nut attached to the small bolt holding the antenna has come loose. I’ve tried my best to remove the panel, but to no avail. My Insignia HD has a little different configuration then the one you posted, and has only TWO phillips screws near the top. Any suggestions on how to remove the panel? Thanks, <michaelk29@hotmail.com>
