Insignia NS-F12R6-SS Upper Oscillation Gear Replacement
  1. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Front Cage: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Front Cage: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug your fan.
    • Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
  2. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ring that runs around the edge of the fan cage.
  3. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front of the fan cage.
  4. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Fan Blade: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
  5. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take caution when removing the fan blades. They can be sharp!
    • Slide the fan blade off the end of the rotor.
  6. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Back Cage: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
  7. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the back cage off.
  8. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Oscillation Button: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Oscillation Button: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 10 mm screw in the center hole of the oscillation knob with a Phillips #3 screwdriver.
  9. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the oscillation knob.
  10. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Motor Housing: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to gently pull the power knob directly away from the motor housing.
  11. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the flat 17 mm nut fastened at the bottom of the power knob with a small crescent wrench.
  12. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 6 mm bolts and small washers that secure the front face of the motor housing with a Phillips #3 screwdriver and remove the washers.
  13. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the front face of the motor housing off toward the front of the rotor.
  14. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 10 mm triangular-headed bolt with a Phillips #3 screwdriver.
  15. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the back end of the motor housing away from the front of the rotor.
  16. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the small piece of paper hanging on the power button.
  17. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Upper Oscillation Gear: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Upper Oscillation Gear: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Upper Oscillation Gear: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #3 screwdriver, unscrew and remove the 7 mm long bolt and small washer fastening the yellow and green wire to the motor housing support.
  18. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #3 screwdriver unscrew the 13 mm long screw fastening the motor housing support to the oscillation gear box.
  19. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #3 screwdriver, unscrew the three 13 mm long screws fastening the grey plate to the top of the oscillation gear box.
    • Remove the grey cap covering the oscillation gear box.
  20. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the upper oscillation gear.
Hank
crwdns2935283:009/17/18crwdne2935283:0
1,142 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team S2-G1, Bruce Fall 2018 crwdns2935289:0CSU Fullerton, Team S2-G1, Bruce Fall 2018crwdne2935289:0
CSUF-BRUCE-F18S2G1
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 683
