Removing the back of the fan cage provides access to the motor housing.
            Unplug your fan.
            Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
            Remove the ring that runs around the edge of the fan cage.
            Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
            Slide the fan blade off the end of the rotor.
            Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
