Turn the power off. Slide the power button to OFF.
Unplug AC adapter from car cigarette lighter.
Make sure there is no DVD or CD in the disc tray
Unscrew the nine 9mm screws with a JIS #000 screwdriver.
Pry off back panel with prying tool, then remove by hand.
After the back is removed and you can see the interior of the device, push the old latch out.
Push the new latch in where the old latch was previously held
You can lightly tap it from the inside to make sure the new latch is sliding left and right.
