Refer to the Insignia NS-CLOPP2 Screen Replacement Guide before beginning the motherboard replacement. Then, use this four step guide to replace the motherboard for your Insignia NS-CLOPP2. Motherboard replacement for clock radios can solve issues related to the speaker, LED display, sleep timer, and other technical elements.
First, remove the front screen. (See prerequisite screen removal guide.)
Use the plastic opening tool to gently pry the motherboard forward and away from the rest of the device.
Gently lift the motherboard up and out, making sure that you don't disassemble any of the wires in place by pulling too hard.
To fully remove the motherboard from the clock, use wire cutters to carefully sever the connections between the motherboard and the wires attached.
